Voltage on the chassis Philco 38-8
Well yes it is the xfmr, there is no other ways to leak.
Again, it is probably benign and is what most radios will have.
I recommended measuring the current just to make sure it is small.
Wouldn't hurt to know it for a fact.
There are two paths to induce the voltage through the transformer: 1) via the capacitance of the primary to the shell which is connected to chassis, and through the capacitance to the secondaries, which then through the capacitors or simply through grounded filaments bring it there.
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-17-2016, 03:53 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 10:10 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:09 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 09:37 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:45 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-19-2016, 10:00 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 10:08 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 02:00 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 09:05 PM
Restoring Philco 96
There are currently 4506 online users. [Complete List]
» 3 Member(s) | 4503 Guest(s)
