Model 650 Cap 77, 10mfd, Polarity Question
The center tap being the most negative point the chassis is more positive. I would connect the + to chassis.
RE: Model 650 Cap 77, 10mfd, Polarity Question - by KCMike - 03-21-2016, 11:15 AM
Restoring Philco 96
There are currently 7437 online users. [Complete List]
» 3 Member(s) | 7434 Guest(s)
