Model 650 Cap 77, 10mfd, Polarity Question
The positive terminal should connect to chassis ground, and the negative to the center tap.
The center tap is the most negative voltage  point in the circuit, so the negative terminal of the cap connects there.
RE: Model 650 Cap 77, 10mfd, Polarity Question - by Mondial - 03-21-2016, 11:17 AM
Restoring Philco 96
There are currently 7455 online users. [Complete List]
» 3 Member(s) | 7452 Guest(s)
