Model 650 Cap 77, 10mfd, Polarity Question
Yes this is one of those questions asked about few hundred times here.
The connection is counter-intuitive, as people are accustomed to seeing GND being the most negative point and so caps' minusses going to it.
In this case which is present in many radios, the centertap is the most negative point in the whole of the schematic; everything else relative to it is positive.
Hence the capacitor's minus goes to the centertap, and the plus goes to the Ground (chassis).
RE: Model 650 Cap 77, 10mfd, Polarity Question - by morzh - 03-21-2016, 11:26 AM
Restoring Philco 96
There are currently 7431 online users. [Complete List]
» 3 Member(s) | 7428 Guest(s)
