Better reception on one radio, when plugging in another? What the???
I'm thinking that the second radio, which ofcourse has an antenna in it, picks up and relays radio waves through the same electric circuit in the house that the first radio is plugged into and helps it with a stronger signal.  OR maybe the Philcos are haunted !!   (one of those two things).
Restoring Philco 96
There are currently 7708 online users. [Complete List]
» 3 Member(s) | 7705 Guest(s)
