Model 650 Cap 77, 10mfd, Polarity Question
That's the negative supply that offers negative voltages to grids (mostly) throughout the radio. It's a common circuit in most radios, primarily the better ones.  You don't need a high voltage cap in these circuits and 50 volts is very safe. As in the other posts, this cap has a positive connected to ground.
Pete AI2V
RE: Model 650 Cap 77, 10mfd, Polarity Question - by AI2V - 03-22-2016, 07:39 PM
There are currently 6659 online users. [Complete List]
» 1 Member(s) | 6658 Guest(s)
