41-250 Cabinet Graphics & Refinishing
I hate to rain on your parade, but...
Winky Dink, your graphics look great...however, the font for the call letter tabs is incorrect. You really should use the font which you may download here, from the Phorum:
http://www.philcoradio.com/phorum/showth...p?tid=5148
RE: 41-250 Cabinet Graphics & Refinishing - by Ron Ramirez - 03-23-2016, 10:10 PM
There are currently 9938 online users. [Complete List]
» 2 Member(s) | 9936 Guest(s)
