deciphering Philco Potentiometer numbers
Keith
Have you tried Oldradioparts?
On a smaller Philco I successfully used a today's pot.
Also sometimes if the pot is still a pot, only with much higher value, some effect could be achieved by simply paralleling a resistor across the end pins, so the total resistance is in this case 350K (500K resistor).
In some cases even without doing anything it will work.
RE: deciphering Philco Potentiometer numbers - by morzh - 03-24-2016, 08:39 AM
Restoring Philco 96
There are currently 7691 online users. [Complete List]
» 3 Member(s) | 7688 Guest(s)
