37-670 Glowing Beam Indicator Problem
This lens simply focuses the beam.
So you need to 1) make sure the dial is in focus of the lens, 2) the light bulb's filament oriented such that it creates a vertical most narrow line. If you need to adjust something - do it. Just do not break the glass rod.
37-670 Glowing Beam Indicator Problem - by davemc - 03-23-2016, 05:32 PM
RE: 37-670 Glowing Beam Indicator Problem - by morzh - 03-24-2016, 03:13 PM
Restoring Philco 96
There are currently 6542 online users. [Complete List]
» 5 Member(s) | 6537 Guest(s)
AvatarAvatarAvatarAvatar
