Restoration
So where could one get simplified information about the function of each device in my model 70? As I prepare for the restoration, I'd sure like to have a better idea of what each part specifically does in the circuit. I was contemplating even painting the chassis, which would require a total stripping (gulp) I figure if I can't get it back together, I'll put a clock radio in behind the grill! Nah. I just would like to go through and restore the 70 and have a better understanding of how it works, then focus my attention on the other philco I have (model not known) so I can hear short wave! If anyone could steer me into some very simplified detail of the model 70 chassis though, I'd really appreciate it. Of course I will be consulting all of you too, along the way, for your input.
tractorforum.com *** I reserve the right to be wrong
Restoration - by Music in a bottle - 05-20-2009, 08:55 PM
Re: Restoration - by g8wayg8r - 05-20-2009, 10:09 PM
Re: Restoration - by exray - 05-21-2009, 07:46 AM
Re: Restoration - by Music in a bottle - 05-21-2009, 10:11 PM
Re: Restoration - by exray - 05-21-2009, 11:38 PM
Re: Restoration - by kruc - 05-23-2009, 04:44 AM
Re: Restoration - by Music in a bottle - 05-23-2009, 10:51 PM
There are currently 8451 online users. [Complete List]
» 3 Member(s) | 8448 Guest(s)
