37-670 Glowing Beam Indicator Problem
The lamp and reflector is definitely too high and off to one side. It appears the bracket is bent, as it should be perpendicular to the dial.
The lamp should be directly behind the glass lens and centered vertically with respect to the dial scales. Otherwise the lens will not focus the beam indicator sharply.
37-670 Glowing Beam Indicator Problem - by davemc - 03-23-2016, 05:32 PM
RE: 37-670 Glowing Beam Indicator Problem - by Mondial - 03-24-2016, 05:12 PM
There are currently 6716 online users. [Complete List]
» 2 Member(s) | 6714 Guest(s)
