deciphering Philco Potentiometer numbers
Thanks Morzh,  I've contacted oldradioparts and I'm pretty sure he can make me a new pot.  I went ahead and opened it up to see why the switch wasn't working.  There is a metal tab that has been folded back and forth  to the point where it is literally held on by a thin tread of metal.  If I could find a pot with this same type of switch I could probably fix the switch and then fix the pot by putting a resistor across the terminals as you suggested.  Is this a common switch type?
Keith
RE: deciphering Philco Potentiometer numbers - by keith49vj3 - 03-24-2016, 08:03 PM
Restoring Philco 96
There are currently 6551 online users. [Complete List]
» 5 Member(s) | 6546 Guest(s)
AvatarAvatarAvatarAvatar
