Adding fuse to 38-4.
I'm a fast blow man too! Usually 1.5A for 5-6 toobers. In spite of what is said about nuisance blowing I've never had it happen. A decent fault should take out a 1.5 or 2 amp fast blow just as fast.
Some slow blow fuses will allow up to 400% for a second or two? and 200% for even longer.
Adding fuse to 38-4. - by garyh1 - 03-09-2009, 02:06 PM
Re: Adding fuse to 38-4. - by mandh - 03-09-2009, 03:04 PM
Re: Adding fuse to 38-4. - by MinnesotaHam - 03-09-2009, 07:18 PM
Re: Adding fuse to 38-4. - by Arran - 03-10-2009, 05:38 PM
Re: Adding fuse to 38-4. - by g8wayg8r - 05-19-2009, 11:09 PM
Re: Adding fuse to 38-4. - by mandh - 05-21-2009, 07:47 PM
Re: Adding fuse to 38-4. - by exray - 05-21-2009, 08:23 PM
Re: Adding fuse to 38-4. - by codefox1 - 05-22-2009, 03:47 PM
There are currently 7235 online users. [Complete List]
» 1 Member(s) | 7234 Guest(s)
