Philco 50-T702
Nice find! That chassis looks decent. A simple electrostatic deflected set. Take your time in the rebuild and do a section at a time, starting with the power supply electrolytics. Generally you can tell your mica caps by the smaller values, in PF, MMF, uuF or something similar, your paper caps are larger (.01, .001 mf, mfd, uf, and such). Can be a little confusing at first since some of those look like micas. The black striped 'bumble bee' caps are also paper caps and should be replaced. You can take them out and sell them on Ebay $$$ Icon_twisted I hope you can find a set of knobs, or something that will look correct anyway. Keep us up on the progress.
Tim
Philco 50-T702 - by Crist Rigotti - 03-25-2016, 05:43 PM
RE: Philco 50-T702 - by Crist Rigotti - 03-25-2016, 05:54 PM
RE: Philco 50-T702 - by Mondial - 03-25-2016, 06:11 PM
RE: Philco 50-T702 - by TV MAN - 03-26-2016, 09:23 AM
RE: Philco 50-T702 - by Crist Rigotti - 03-26-2016, 11:51 AM
RE: Philco 50-T702 - by Crist Rigotti - 03-26-2016, 06:24 PM
RE: Philco 50-T702 - by Crist Rigotti - 03-26-2016, 08:12 PM
RE: Philco 50-T702 - by mikethedruid - 03-27-2016, 04:33 PM
RE: Philco 50-T702 - by Crist Rigotti - 03-27-2016, 08:04 PM
RE: Philco 50-T702 - by gregb - 03-28-2016, 12:25 AM
RE: Philco 50-T702 - by Crist Rigotti - 03-28-2016, 09:26 PM
RE: Philco 50-T702 - by gregb - 03-28-2016, 10:10 PM
RE: Philco 50-T702 - by Crist Rigotti - 03-28-2016, 11:38 PM
RE: Philco 50-T702 - by gregb - 03-28-2016, 11:46 PM
RE: Philco 50-T702 - by Crist Rigotti - 03-30-2016, 09:42 AM
RE: Philco 50-T702 - by Crist Rigotti - 03-30-2016, 09:15 PM
RE: Philco 50-T702 - by TV MAN - 03-31-2016, 01:59 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-01-2016, 10:55 PM
RE: Philco 50-T702 - by mikethedruid - 04-05-2016, 04:20 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-06-2016, 09:20 AM
RE: Philco 50-T702 - by Kenneth F. Besso Jr. - 04-06-2016, 06:48 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-06-2016, 07:11 PM
RE: Philco 50-T702 - by Radioroslyn - 04-06-2016, 09:56 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-07-2016, 12:01 AM
RE: Philco 50-T702 - by Radioroslyn - 04-07-2016, 03:42 PM
RE: Philco 50-T702 - by Kenneth F. Besso Jr. - 04-07-2016, 04:50 PM
RE: Philco 50-T702 - by mikethedruid - 04-07-2016, 05:02 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-09-2016, 11:08 PM
RE: Philco 50-T702 - by TV MAN - 04-10-2016, 01:42 PM
RE: Philco 50-T702 - by mikethedruid - 04-10-2016, 08:07 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-10-2016, 08:39 PM
RE: Philco 50-T702 - by gregb - 04-10-2016, 08:57 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-11-2016, 12:00 PM
RE: Philco 50-T702 - by Eliot Ness - 04-11-2016, 12:04 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-12-2016, 12:51 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-12-2016, 12:54 AM
RE: Philco 50-T702 - by Mondial - 04-12-2016, 08:02 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-12-2016, 09:05 AM
RE: Philco 50-T702 - by Kenneth F. Besso Jr. - 04-12-2016, 06:32 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-13-2016, 10:57 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-13-2016, 10:58 PM
RE: Philco 50-T702 - by mikethedruid - 04-13-2016, 11:46 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-14-2016, 10:30 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-18-2016, 12:18 AM
RE: Philco 50-T702 - by TV MAN - 04-18-2016, 07:53 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-18-2016, 09:52 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-18-2016, 01:55 PM
RE: Philco 50-T702 - by mikethedruid - 04-18-2016, 10:42 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-19-2016, 12:41 AM
RE: Philco 50-T702 - by TV MAN - 04-19-2016, 07:49 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-19-2016, 10:29 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-25-2016, 10:41 PM
RE: Philco 50-T702 - by Eliot Ness - 04-26-2016, 08:38 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-26-2016, 09:52 AM
RE: Philco 50-T702 - by Mondial - 04-26-2016, 11:37 AM
RE: Philco 50-T702 - by Crist Rigotti - 04-26-2016, 12:29 PM
RE: Philco 50-T702 - by Radioroslyn - 04-26-2016, 01:34 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-28-2016, 08:23 PM
RE: Philco 50-T702 - by Crist Rigotti - 04-30-2016, 10:52 PM
RE: Philco 50-T702 - by Arran - 05-17-2016, 03:36 AM
RE: Philco 50-T702 - by Crist Rigotti - 05-18-2016, 12:50 PM
RE: Philco 50-T702 - by TV MAN - 05-19-2016, 11:19 PM
RE: Philco 50-T702 - by Crist Rigotti - 05-20-2016, 08:03 PM
RE: Philco 50-T702 - by Arran - 05-21-2016, 02:03 AM
RE: Philco 50-T702 - by Crist Rigotti - 06-28-2016, 11:28 PM
