voice coil for philco 37-116
Hi everyone , I’m working on 1937-philco model 37-116 . I just finished recapping, changed the power resistors, all the electrolitics, rubber chassis mounts, added an exterior fuse, new/ 3 pull on/off /bass/bass switch, new dial, cloth grill and some other things I just can think of now. The recapping was a lot work and time consuming !!   As of now i’m over 100 hours and counting. The problem I have now is the voice coil in the speaker is bad. I do have a speaker paper that is the same size. When I was about 3/4 the way done with the recapping,I  fired it up. It played well with another speaker tied into the old speaker transformer. Does anyone on this fine board, known where I can purchase a voice coil that will work. I did check on line, but so far negative results. also does anyone know how many ohms this speaker is? Any help would be appreciated.    Thanks Jeff
voice coil for philco 37-116 - by radio jeff - 03-26-2016, 03:14 PM
RE: voice coil for philco 37-116 - by Radioroslyn - 03-27-2016, 05:15 PM
RE: voice coil for philco 37-116 - by radio jeff - 04-01-2016, 09:45 AM
RE: voice coil for philco 37-116 - by radio jeff - 04-02-2016, 03:00 PM
RE: voice coil for philco 37-116 - by Radioroslyn - 04-02-2016, 07:17 PM
RE: voice coil for philco 37-116 - by radio jeff - 04-10-2016, 08:42 AM
There are currently 6665 online users. [Complete List]
» 1 Member(s) | 6664 Guest(s)
