Adding fuse to 38-4.
I'd have to agree with fast blow for all tube applications. They are easy to come by too. 1 amp is ususally sufficient for small AC-DC sets. It's not a bad idea to put another fuse in the B+ circuit. This can be a 1/2 amp or smaller depending on the draw. Beats scouring Epay for yet another obscure tube.
Adding fuse to 38-4. - by garyh1 - 03-09-2009, 02:06 PM
Re: Adding fuse to 38-4. - by mandh - 03-09-2009, 03:04 PM
Re: Adding fuse to 38-4. - by MinnesotaHam - 03-09-2009, 07:18 PM
Re: Adding fuse to 38-4. - by Arran - 03-10-2009, 05:38 PM
Re: Adding fuse to 38-4. - by g8wayg8r - 05-19-2009, 11:09 PM
Re: Adding fuse to 38-4. - by mandh - 05-21-2009, 07:47 PM
Re: Adding fuse to 38-4. - by exray - 05-21-2009, 08:23 PM
Re: Adding fuse to 38-4. - by codefox1 - 05-22-2009, 03:47 PM
There are currently 10319 online users. [Complete List]
» 1 Member(s) | 10318 Guest(s)
