voice coil for philco 37-116
A little odd. You may want to check the leads going from the vc to the terminals on the output transformer and hum bucking coil. The wire size is enough that it should fail with some help. If the HB coil is open I'd jumper it out.
voice coil for philco 37-116 - by radio jeff - 03-26-2016, 03:14 PM
RE: voice coil for philco 37-116 - by Radioroslyn - 03-27-2016, 05:15 PM
RE: voice coil for philco 37-116 - by radio jeff - 04-01-2016, 09:45 AM
RE: voice coil for philco 37-116 - by radio jeff - 04-02-2016, 03:00 PM
RE: voice coil for philco 37-116 - by Radioroslyn - 04-02-2016, 07:17 PM
RE: voice coil for philco 37-116 - by radio jeff - 04-10-2016, 08:42 AM
Restoring Philco 96
There are currently 7844 online users. [Complete List]
» 2 Member(s) | 7842 Guest(s)
