40-150 No SW
Well I just reinstalled the coil after baking at 150 deg for about an hour an a half, no change. The coils all ohm out ok and the switches are all wired right and still no shortwave. I think I have to put this one aside for a while.
Gregb
40-150 No SW - by gregb - 03-26-2016, 04:18 PM
RE: 40-150 No SW - by pbert - 03-26-2016, 06:03 PM
RE: 40-150 No SW - by klondike98 - 03-26-2016, 06:19 PM
RE: 40-150 No SW - by gregb - 03-26-2016, 08:35 PM
RE: 40-150 No SW - by gregb - 03-28-2016, 12:01 AM
RE: 40-150 No SW - by David - 03-28-2016, 09:04 PM
RE: 40-150 No SW - by gregb - 03-28-2016, 10:07 PM
RE: 40-150 No SW - by Arran - 03-29-2016, 03:47 AM
RE: 40-150 No SW - by gregb - 03-29-2016, 08:55 AM
RE: 40-150 No SW - by Ron Ramirez - 03-29-2016, 05:50 AM
RE: 40-150 No SW - by gregb - 03-29-2016, 08:56 AM
RE: 40-150 No SW - by fifties - 03-29-2016, 08:54 PM
RE: 40-150 No SW - by gregb - 03-29-2016, 09:05 PM
RE: 40-150 No SW - by Raleigh - 04-13-2016, 12:39 AM
RE: 40-150 No SW - by gregb - 04-13-2016, 09:10 AM
Restoring Philco 96
There are currently 7376 online users. [Complete List]
» 4 Member(s) | 7372 Guest(s)
AvatarAvatarAvatarAvatar
