Restoration
Thanks to both of you guys. I ran off a copy of this page. I recently used on loan, a very old Weston? I think. It was in the original case, and was so big and old, that a had a beard almost as long as mine! I was thinking of getting an older iron, seeings how I seem to love antique things. Bill, have you ever seen the inside of a Marantz model 7t? It's just a solid state preamp with no printed circuit boards, all point to point connections. They're a real work of art for the late 1960s, in the day of the beginning Japanese electronics. I have a real nice 7t and occasionally I remove the covers to check out the quality. I'm starting to get all pumped about going to work on my model 70. It works now, and when I'm done, I'm sure it wont!
tractorforum.com *** I reserve the right to be wrong
Restoration - by Music in a bottle - 05-20-2009, 08:55 PM
Re: Restoration - by g8wayg8r - 05-20-2009, 10:09 PM
Re: Restoration - by exray - 05-21-2009, 07:46 AM
Re: Restoration - by Music in a bottle - 05-21-2009, 10:11 PM
Re: Restoration - by exray - 05-21-2009, 11:38 PM
Re: Restoration - by kruc - 05-23-2009, 04:44 AM
Re: Restoration - by Music in a bottle - 05-23-2009, 10:51 PM
