Philco 39-8t extra parts and wire
Hi and welcome,
Philco set never used a resistance line cord they did however use power resistor/s mounted to the chassis.Would just rewire as per the schematic and forget what was done in the past.
RE: Philco 39-8t extra parts and wire - by Radioroslyn - 03-30-2016, 06:34 AM
RE: Philco 39-8t extra parts and wire - by morzh - 03-30-2016, 12:01 PM
There are currently 3976 online users. [Complete List]
» 3 Member(s) | 3973 Guest(s)
