Thinking about buying model 630 Console?
Looks to be a very restorable receiver. The cabinet does not look too bad either, very restorable. Should be a fun project. I look forward to your postings and progress when you work on it. Great find and a good price. Good luck with it.
I bought the model 630 Console. - by philconerd - 03-23-2016, 11:22 AM
RE: Thinking about buying model 630 Console? - by mikethedruid - 03-30-2016, 10:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6828 online users. [Complete List]
» 1 Member(s) | 6827 Guest(s)
