Threads: 83
City: Annapolis, IL
State, Province, Country: USA
Glad you found that bad solder point. That surly would have been the source of an intermittent, and may be the reason it got retired before enough use to require a bunch of replacement parts, and explain the very good picture tube.
Tim
RE: Philco 50-T702 - by TV MAN - 03-31-2016, 01:59 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
