Philco 90 filament section on PT bad
Yes, sounds plausible.
He said though he resoldered something in the xfmr.
The leads from the very first tube where the xfmr connects, that could be bad spot there.
I am still not convinced the xfmr is bad.
Philco 90 filament section on PT bad - by Skip - 04-02-2016, 02:08 PM
RE: Philco 90 filament section on PT bad - by morzh - 04-02-2016, 10:03 PM
RE: Philco 90 filament section on PT bad - by OZ4 - 04-03-2016, 12:02 PM
Restoring Philco 96
There are currently 7473 online users. [Complete List]
» 3 Member(s) | 7470 Guest(s)
