Cathedral Top Repair - Advice Needed
Jay, It's not too hard to replace the complete wraparound. I have done it on a couple of my cathedrals. I had a local lumber yard order a sheet of 1/8 inch Lauan plywood. Just take the cabinet apart and use the old piece as a pattern.
M R Radios   C M Tubes
Re: Cathedral Top Repair - Advice Needed - by Steve Davis - 05-26-2009, 09:40 PM
Philco 91 Tuning Condenser
There are currently 10441 online users. [Complete List]
» 2 Member(s) | 10439 Guest(s)
