Philco 90 filament section on PT bad
Skip, make sure you are measuring the transformer voltage directly at the transformer leads. If you are connecting the voltmeter probes after the clip leads or ammeter, you will see a large voltage drop as the leads have significant resistance. You could easily see a drop of 1 volt when passing 8 or 10 amps through a typical clip lead.
With a 2.5 v supply it is very critical to have a minimum of resistance in the connections and wiring, which is one reason 2.5 volt filaments were abandoned in favor of 6.3 v tubes in later sets.
Philco 90 filament section on PT bad - by Skip - 04-02-2016, 02:08 PM
RE: Philco 90 filament section on PT bad - by OZ4 - 04-03-2016, 12:02 PM
RE: Philco 90 filament section on PT bad - by Mondial - 04-03-2016, 02:15 PM
Restoring Philco 96
There are currently 7586 online users. [Complete List]
» 3 Member(s) | 7583 Guest(s)
