Philco 40-201 Restoration Journal
Does anyone know the color of power-on jewel that's always missing from these radios?
Philco 40-201 Restoration Journal - by g8wayg8r - 05-14-2009, 12:41 AM
Re: Philco 40-201 Restoration Journal - by g8wayg8r - 05-28-2009, 06:33 PM
There are currently 9900 online users. [Complete List]
» 1 Member(s) | 9899 Guest(s)
