Philco 37-670 Shadow Meter Woes
Very helpful - thanks! So likely my magnet is there and simply needs to be "recharged".  Did you remove your magnet, or was it a previous owner?  It also appears that your coil has been rewound.  Mine is OK. It appears that to remove the coil I need to straighten the bent over tabs holding the lamp bracket and remove the bracket.  The coil and magnet looks like it can then slide off.  I suppose I then melt the wax and remove the magnet for recharging.  I have seen the recharging procedure on-line.  I have several powerful magnets available for stroking my magnet from one end to the other in the same direction, and check attraction using a pin or other small object. IIRC you said your magnet was reattached using a dab of hot glue.
While disassembled, I assume I need to check for proper vane movement.
If you did your repairs yourself, please confirm the procedure outlined above.
Thanks again, Dave
Philco 37-670 Shadow Meter Woes - by davemc - 03-30-2016, 09:46 AM
RE: Philco 37-670 Shadow Meter Woes - I give up! - by davemc - 04-05-2016, 07:48 AM
RE: Philco 37-670 Shadow Meter Woes - by titan1a - 05-03-2016, 08:45 PM
Restoring Philco 96
There are currently 4346 online users. [Complete List]
» 3 Member(s) | 4343 Guest(s)
