Philco 37-670 Shadow Meter Woes
I was wondering about that too.
My doubt was about this: if there is half missing (it is next to impossible to do anything to this meter without utterly destroying it to make it break in half in the first place), the meter is fairly enclosed space, the other half would still be inside.
Philco 37-670 Shadow Meter Woes - by davemc - 03-30-2016, 09:46 AM
RE: Philco 37-670 Shadow Meter Woes - I give up! - by morzh - 04-07-2016, 08:44 AM
RE: Philco 37-670 Shadow Meter Woes - by titan1a - 05-03-2016, 08:45 PM
Restoring Philco 96
There are currently 7765 online users. [Complete List]
» 2 Member(s) | 7763 Guest(s)
