DELCO 4052 ACDC (was 43 tubes)
Oh it is shielded.
The hum only is present when the station is heard, otherwise no. So not really PS nor it is the amp.
Will try alignment.
I have another 25Z5.
DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-05-2016, 10:18 PM
RE: 43 tubes - by Phlogiston - 04-05-2016, 11:19 PM
RE: 43 tubes - by morzh - 04-05-2016, 11:43 PM
RE: 43 tubes - by Arran - 04-06-2016, 04:01 AM
RE: 43 tubes - by morzh - 04-06-2016, 08:19 AM
RE: 43 tubes - by Phlogiston - 04-06-2016, 11:15 AM
RE: 43 tubes - by Phlogiston - 04-06-2016, 03:17 PM
RE: 43 tubes - by morzh - 04-06-2016, 07:43 PM
RE: 43 tubes - by Phlogiston - 04-06-2016, 08:31 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-06-2016, 11:47 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-07-2016, 11:38 AM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-07-2016, 04:27 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-07-2016, 05:04 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-07-2016, 07:06 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-07-2016, 11:14 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by Arran - 04-07-2016, 11:51 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-08-2016, 08:09 AM
RE: DELCO 4052 ACDC (was 43 tubes) - by TV MAN - 04-08-2016, 08:30 AM
RE: DELCO 4052 ACDC (was 43 tubes) - by Joe Rossi - 04-09-2016, 02:21 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-09-2016, 11:13 AM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-09-2016, 06:13 PM
RE: DELCO 4052 ACDC (was 43 tubes) - by morzh - 04-10-2016, 07:52 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
