Philco 20 cathedral conversion?
I would never convert. I had harder time finding the plain in good shape than the Deluxe.
Plus...what to do with the grooves? Deluxe does not have them and the bezel does not cover it.
I would advise against it.
Philco 20 cathedral conversion? - by sdradioman - 04-07-2016, 09:28 PM
RE: Philco 20 cathedral conversion? - by morzh - 04-07-2016, 11:17 PM
RE: Philco 20 cathedral conversion? - by morzh - 04-08-2016, 08:31 AM
RE: Philco 20 cathedral conversion? - by morzh - 04-09-2016, 10:23 AM
RE: Philco 20 cathedral conversion? - by morzh - 04-09-2016, 12:47 PM
RE: Philco 20 cathedral conversion? - by GarySP - 04-09-2016, 05:23 PM
RE: Philco 20 cathedral conversion? - by Arran - 04-12-2016, 04:33 AM
There are currently 10524 online users. [Complete List]
» 2 Member(s) | 10522 Guest(s)
