Philco 90 grid voltage and RF choke
David
What grid Vs are negative? The 45's are supposed to be.
No the choke won't change grid Vs and the detector works without it.
You need to be more posts exact in your statements.
Philco 90 grid voltage and RF choke - by Davidra - 04-10-2016, 02:26 PM
RE: Philco 90 grid voltage and RF choke - by morzh - 04-10-2016, 07:48 PM
Restoring Philco 96
There are currently 5812 online users. [Complete List]
» 5 Member(s) | 5807 Guest(s)
AvatarAvatarAvatarAvatar
