Will a 655 fit in a cabinet for a 610?
(04-10-2016, 09:49 PM)Ron Ramirez Wrote:  Nope.
The control shafts of a 610 are closer together than the control shafts of a 655. Not to mention the larger escutcheon, and shadow meter...
Now, you could install a 620, or even a 630. But nothing larger.
Thanks Ron, I was thinking of bidding on a 655,  good thing I asked.
Keith
RE: Will a 655 fit in a cabinet for a 610? - by keith49vj3 - 04-11-2016, 06:07 AM
