Tube Shield Finish
I have some that have retained most of their original non-corroded finish and they are a bright nickel/zinc type plating. I would think a spray finish that was fine aluminum or had a nickel type appearance would be ok. Some of mine are faded/corroded not from water exposure but probably from being handled, anything close would look better.
Tube Shield Finish - by Derek D - 01-04-2006, 11:24 AM
[No subject] - by Ron Ramirez - 01-05-2006, 12:49 PM
[No subject] - by Derek D - 01-05-2006, 12:59 PM
[No subject] - by 49Stude63 - 01-05-2006, 01:40 PM
[No subject] - by Terry Judkins - 01-05-2006, 10:06 PM
[No subject] - by Guest - 01-06-2006, 02:46 AM
