Philco 20 cathedral conversion?
(04-07-2016, 09:28 PM)sdradioman Wrote:  Has anyone out there ever converted a regular model 20 cathedral to a deluxe model? Do they make repop burlwood fronts and the columns below them?
 I can't really see the point since model 20s with the so called "Deluxe" cabinet are not that hard to find, plus as Mike stated I don't think you could cover up those scrolls cut into the front panel of the flat faced earlier version. I'm not sure if he reproduces them as yet but Steve Davis may plan to in future.
Philco 20 cathedral conversion? - by sdradioman - 04-07-2016, 09:28 PM
RE: Philco 20 cathedral conversion? - by morzh - 04-07-2016, 11:17 PM
RE: Philco 20 cathedral conversion? - by morzh - 04-08-2016, 08:31 AM
RE: Philco 20 cathedral conversion? - by morzh - 04-09-2016, 10:23 AM
RE: Philco 20 cathedral conversion? - by morzh - 04-09-2016, 12:47 PM
RE: Philco 20 cathedral conversion? - by GarySP - 04-09-2016, 05:23 PM
RE: Philco 20 cathedral conversion? - by Arran - 04-12-2016, 04:33 AM
