Philco 41-290 Chassis: Any Cautions?
Hi! I just acquired a 41-290 console with an excellent-plus cabinet (yea!), dial group and grille cloth. Chassis (121) and speaker now have been removed and ready for refurbishment. Are there any major issues I should specifically look for or be very wary about that are/may be specific to this particular 10 tube chassis? Thanks! Frank
Philco 41-290 Chassis: Any Cautions? - by Pol-Cat - 06-03-2009, 04:14 PM
There are currently 11320 online users. [Complete List]
» 2 Member(s) | 11318 Guest(s)
