Post re-cap 38-4 hum.
(04-12-2016, 10:02 PM)morzh Wrote:  Is the hum constant level or does it change across the dial?
Was the humbucker in the speaker ever touched? Is it present?
Were all tubes checked for shorts, especially HK ones?
Is the GND good throughout the chassis?
Last thing, a little hum might be normal.
Last thing, some
Thank you for the reply,
The hum is constant not affected by volume or tuning. All tubes TV7 tested good or better. I would love to know how to thoroughly check chassis grounds.
FF
HE>i
Post re-cap 38-4 hum. - by hffenninger - 04-11-2016, 12:58 AM
RE: Post re-cap 38-4 hum. - by klondike98 - 04-11-2016, 08:46 AM
RE: Post re-cap 38-4 hum. - by hffenninger - 04-11-2016, 08:13 PM
RE: Post re-cap 38-4 hum. - by hffenninger - 04-11-2016, 08:25 PM
RE: Post re-cap 38-4 hum. - by Radioroslyn - 04-11-2016, 08:57 PM
RE: Post re-cap 38-4 hum. - by mikethedruid - 04-11-2016, 09:54 PM
RE: Post re-cap 38-4 hum. - by hffenninger - 04-12-2016, 08:34 PM
RE: Post re-cap 38-4 hum. - by morzh - 04-12-2016, 10:02 PM
RE: Post re-cap 38-4 hum. - by hffenninger - 04-12-2016, 10:59 PM
RE: Post re-cap 38-4 hum. - by morzh - 04-13-2016, 10:39 AM
RE: Post re-cap 38-4 hum. - by hffenninger - 04-13-2016, 04:05 PM
RE: Post re-cap 38-4 hum. - by morzh - 04-13-2016, 04:58 PM
Restoring Philco 96
There are currently 7446 online users. [Complete List]
» 3 Member(s) | 7443 Guest(s)
