Philco 89B won't oscillate!
(04-13-2016, 06:31 PM)Radioroslyn Wrote:  So if you measure the resistance from pin 4 of the 36 tube to the pin on the osc coil that has the resistor (15K) and cap (700mmfd) connected to it what do you  get???
Terry, I don't see a resistor or capacitor going to the O-coil. But pin #4 of the 36 goes to pin 1 of the O-coil. From that point, I get nothing- open on the other 4 pins. . I get 8.5 Ohms from the top cap 36 to gnd. O-coil OPEN?
SM
Philco 89B won't oscillate! - by Steve McDonald - 04-13-2016, 02:00 PM
RE: Philco 89B won't oscillate! - by morzh - 04-13-2016, 05:03 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 06:31 PM
RE: Philco 89B won't oscillate! - by Steve McDonald - 04-13-2016, 07:14 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 07:34 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 08:48 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 09:00 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 10:34 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 11:43 PM
RE: Philco 89B won't oscillate! - by morzh - 04-14-2016, 03:13 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-14-2016, 08:10 PM
RE: Philco 89B won't oscillate! - by KCMike - 04-14-2016, 10:30 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-02-2016, 06:38 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-06-2016, 03:24 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-06-2016, 05:53 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 05-09-2016, 07:51 PM
RE: Philco 89B won't oscillate! - by KCMike - 05-10-2016, 02:13 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 05-10-2016, 02:34 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 07:57 AM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 07:09 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 09:28 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-12-2016, 08:18 AM
89B DOES Oscillate!! - by Steve McDonald - 05-02-2016, 05:03 PM
89B DOES Oscillate!! - by Steve McDonald - 05-06-2016, 03:09 PM
Restoring Philco 96
There are currently 7621 online users. [Complete List]
» 3 Member(s) | 7618 Guest(s)
