Philco 89B won't oscillate!
That would be pin 4 of the 36-cathode. This goes directly to the oscillator coil, pin 1. this pin is not connected to the others. 15K resistor reads 12.8 K . One end of the resistor goes to pin 2 of the O-coil. The other end, to ground. And between pins 1 and 2, there is infinity.
SM
Philco 89B won't oscillate! - by Steve McDonald - 04-13-2016, 02:00 PM
RE: Philco 89B won't oscillate! - by morzh - 04-13-2016, 05:03 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 06:31 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 07:34 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 08:48 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 09:00 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 10:34 PM
RE: Philco 89B won't oscillate! - by Steve McDonald - 04-13-2016, 11:20 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-13-2016, 11:43 PM
RE: Philco 89B won't oscillate! - by morzh - 04-14-2016, 03:13 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 04-14-2016, 08:10 PM
RE: Philco 89B won't oscillate! - by KCMike - 04-14-2016, 10:30 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-02-2016, 06:38 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-06-2016, 03:24 PM
RE: Philco 89B won't oscillate! - by klondike98 - 05-06-2016, 05:53 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 05-09-2016, 07:51 PM
RE: Philco 89B won't oscillate! - by KCMike - 05-10-2016, 02:13 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 05-10-2016, 02:34 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 07:57 AM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 07:09 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-11-2016, 09:28 PM
RE: Philco 89B won't oscillate! - by Radioroslyn - 07-12-2016, 08:18 AM
89B DOES Oscillate!! - by Steve McDonald - 05-02-2016, 05:03 PM
89B DOES Oscillate!! - by Steve McDonald - 05-06-2016, 03:09 PM
Restoring Philco 96
There are currently 5070 online users. [Complete List]
» 4 Member(s) | 5066 Guest(s)
AvatarAvatarAvatarAvatar
