Atwater Kent E2 Speaker Specs
I have an E2 here. Fortunately it works but its really a rather poor sounding speaker. There's not much involved with them IF the driver coil is intact. If not, pass it by.
Its a high-z speaker, not sure of the actual impedance. Probably 2k?
Mine is the floating cone type and the cone is VERY HEAVY paper, almost impervious to damage.
Makes a nice decorating piece even if it were bad.
Atwater Kent E2 Speaker Specs - by g8wayg8r - 06-07-2009, 04:02 PM
Re: Atwater Kent E2 Speaker Specs - by exray - 06-07-2009, 05:38 PM
Re: Atwater Kent E2 Speaker Specs - by Guest - 07-02-2009, 11:42 PM
