An unknown thing of beauty...
(04-20-2016, 06:33 PM)radiohenry Wrote:
(02-09-2016, 08:22 PM)kiwi_steve Wrote:
(02-09-2016, 06:15 PM)Kestas Wrote:  Can you replace the drive belt (string) with an o-ring?  There has been tips lately that one can use a garter spring in place of a belt or o-ring.  Garter springs should last virtually forever.
I don't think so - I can't easily get a closed-loop in place without serious disassembly.  I have some wide flat hair-bands that I'm going to try super-gluing to a suitable length... failing that I'll await the day I need to replace the current setup...
 Steve,
    I looked up the dial belt. You need a JFD # 23. I expect that you should be able to purchase one "down under " for a few dollars. You will also need to look at the condition of the rubber insulating washers used to mount the tuning capacitor. Over time they deteriorate and shrink causing the length of the belt reqiured to change .( become smaller) . If you can't find a belt locally send me a pm with your address and I will put the one I have in the mail for you.
          Good Luck,
                 Henry
Thanks Henry, I'm having trouble getting anything to be reliable in place of a belt.  Knots cause it to jam up, multiple loops of dial cord cause it to occasionally throw one turn off a pulley- in turn causing a jam, anything elastic causes it to have a jerky reaction to tuning... I'll flick you a PM shortly.
And yes, I've replaced the grommets under the tuning condenser - I generally do this as a matter of course since most of them are well and truly deteriorated - the ones in this were rock hard.
Cheers
There are no personal problems that can't be overcome with the liberal application of high explosives
An unknown thing of beauty... - by kiwi_steve - 02-09-2016, 09:02 AM
RE: An unknown thing of beauty... - by Kestas - 02-09-2016, 10:35 AM
RE: An unknown thing of beauty... - by sam - 02-09-2016, 01:28 PM
RE: An unknown thing of beauty... - by kiwi_steve - 02-09-2016, 02:42 PM
RE: An unknown thing of beauty... - by Kestas - 02-09-2016, 06:15 PM
RE: An unknown thing of beauty... - by kiwi_steve - 02-09-2016, 08:22 PM
RE: An unknown thing of beauty... - by radiohenry - 04-20-2016, 06:33 PM
RE: An unknown thing of beauty... - by kiwi_steve - 04-20-2016, 09:32 PM
RE: An unknown thing of beauty... - by Kestas - 02-10-2016, 09:57 AM
RE: An unknown thing of beauty... - by kiwi_steve - 02-11-2016, 01:23 AM
RE: An unknown thing of beauty... - by kiwi_steve - 02-11-2016, 03:29 AM
RE: An unknown thing of beauty... - by TimC - 02-14-2016, 04:47 PM
RE: An unknown thing of beauty... - by Eliot Ness - 02-14-2016, 05:02 PM
RE: An unknown thing of beauty... - by kiwi_steve - 02-15-2016, 04:29 AM
RE: An unknown thing of beauty... - by TimC - 02-15-2016, 01:39 PM
RE: An unknown thing of beauty... - by Art Hoch - 03-10-2016, 06:30 PM
RE: An unknown thing of beauty... - by kiwi_steve - 03-15-2016, 07:15 AM
RE: An unknown thing of beauty... - by Arran - 03-16-2016, 03:50 AM
RE: An unknown thing of beauty... - by kiwi_steve - 04-19-2016, 12:12 AM
RE: An unknown thing of beauty... - by kiwi_steve - 04-19-2016, 07:08 AM
RE: An unknown thing of beauty... - by kiwi_steve - 04-23-2016, 08:24 AM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8394 online users. [Complete List]
» 1 Member(s) | 8393 Guest(s)
