46-250 Rectifier Wiring Question
Thanks Tex,
I use the duncanamps data base for the tube data and I've got all that. The tube data sheets don't say if pins 2 and 4 on the socket of the 35Y4 should be jumpered together. And I'll check again but I didn't see a resistance value for pins 1 to 4 on the 35Y4 on these data sheets. This value isn't that critical. I'm not gonna tear up the chassis to install different sockets to accomodate tubes that didn't come with the set originally.
46-250 Rectifier Wiring Question - by Johnny - 06-09-2009, 10:05 AM
Re: 46-250 Rectifier Wiring Question - by Johnny - 06-10-2009, 12:05 PM
There are currently 10235 online users. [Complete List]
» 2 Member(s) | 10233 Guest(s)
