47-1230 Blown R315 1K Resistor
(04-23-2016, 04:30 PM)Pepperoni Wrote:  Appreciate it Terry. I opened up the Z302 IF can and found C302A, 27pf mica cap reading 88 ohms when isolated. Replaced that with a 25pf silver mica and the radio lives again. I guess that cap just got tired.
Thanks again,
John
I saw that cap but it looked like it has some fairly high resistor hooked to it so was thinking that if it did short that it would load the B+ that much. I hate those newer Philco diagrams where there all split up!
Good Job!!
47-1230 Blown R315 1K Resistor - by Pepperoni - 04-23-2016, 01:58 PM
RE: 47-1230 Blown R315 1K Resistor - by Pepperoni - 04-23-2016, 04:30 PM
RE: 47-1230 Blown R315 1K Resistor - by Radioroslyn - 04-23-2016, 05:45 PM
There are currently 4638 online users. [Complete List]
» 1 Member(s) | 4637 Guest(s)
