37-116 Standard vs. Deluxe?
Seems like I read somewhere that the std was only made for the first 6 months of production. There are a few different version of these sets (37-116 delux). Early ones have push pins to connect the spkr. Later have a socket/plug. Most have 6B4 tubes but the very late ones have 6A5G and the later ones a different LO circuit, less trimmers.
37-116 Standard vs. Deluxe? - by sdradioman - 04-23-2016, 08:26 AM
RE: 37-116 Standard vs. Deluxe? - by Ron Ramirez - 04-23-2016, 08:33 AM
RE: 37-116 Standard vs. Deluxe? - by sdradioman - 04-23-2016, 09:13 AM
RE: 37-116 Standard vs. Deluxe? - by morzh - 04-23-2016, 09:44 AM
RE: 37-116 Standard vs. Deluxe? - by sdradioman - 04-23-2016, 11:45 AM
RE: 37-116 Standard vs. Deluxe? - by Radioroslyn - 04-23-2016, 06:53 PM
RE: 37-116 Standard vs. Deluxe? - by Geoff - 05-17-2016, 01:18 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
