philco paper capacitors
(04-27-2016, 09:25 PM)morzh Wrote:  Then there is femtofarad, ten to the -15, 1/1000 of the picofarad. Radios dontdeal with that but some devices do. I have a friend who measures those.
And no one needs Attofarads. Icon_smile
Mike;
  A femtofarad sounds like something that one would use in UHF or microwave devices. where a straight lenth of wire is considered a coil, but that's just a guess. Bob Andersen once found a 1/2 picofarad/mmf capacitor inside a TV tuner, someone took a very small ceramic cap and then ground part of it away to get the value.
philco paper capacitors - by Up2960 - 04-26-2016, 08:19 PM
RE: philco paper capacitors - by morzh - 04-26-2016, 11:15 PM
RE: philco paper capacitors - by Radioroslyn - 04-27-2016, 12:01 AM
RE: philco paper capacitors - by morzh - 04-27-2016, 09:44 AM
RE: philco paper capacitors - by klondike98 - 04-27-2016, 07:44 AM
RE: philco paper capacitors - by Radioroslyn - 04-27-2016, 10:38 AM
RE: philco paper capacitors - by kiwi_steve - 05-06-2016, 04:17 AM
RE: philco paper capacitors - by mikethedruid - 04-27-2016, 04:01 PM
RE: philco paper capacitors - by morzh - 04-27-2016, 09:25 PM
RE: philco paper capacitors - by Arran - 04-28-2016, 11:03 PM
RE: philco paper capacitors - by Up2960 - 04-27-2016, 07:15 PM
RE: philco paper capacitors - by Radioroslyn - 04-27-2016, 08:14 PM
RE: philco paper capacitors - by Up2960 - 05-07-2016, 05:32 PM
RE: philco paper capacitors - by morzh - 04-27-2016, 09:28 PM
RE: philco paper capacitors - by sam - 04-27-2016, 10:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6931 online users. [Complete List]
» 1 Member(s) | 6930 Guest(s)
