Correct Knobs for a Philco 16B 5 Bands
I an trying to find correct Large Knob for this Radio
I see from Parts List it is P/N  03063 Brown
Now the 16B 5 Band has Push/Pull type tuning for speed , Fast/Slow
I am also under the impression that the knob had a set screw to prevent pulling it off when changing Dial tuning speed.
Any information on this is welcome.
Thank You
Bob T
Correct Knobs for a Philco 16B 5 Bands - by joybird - 05-01-2016, 04:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
