ID this Bracket on Philco 16B chassis
Like they said.
Definitely not factory original.  Dealer or owner add-on.
RE: ID this Bracket on Philco 16B chassis - by Chuck Schwark - 05-03-2016, 09:56 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
