Output transformer for Philco 39-17
Well.....125 SE though will work, is not the best one for the job. Your impefance is really low for it to match it well.
I was always surprised by the fact that 125CT does provide good match for low impedance speakers and SE does not.
I bought my xfmr for a similar speaker from Your Oldradioparts.
If you still are going with 125SE then yes, Blk/Org is the best one.
Output transformer for Philco 39-17 - by Sourbone - 05-05-2016, 10:53 AM
RE: Output transformer for Philco 39-17 - by morzh - 05-05-2016, 08:33 PM
Restoring Philco 96
There are currently 7585 online users. [Complete List]
» 3 Member(s) | 7582 Guest(s)
