A B- Question On My 46-250
Yes. And Pin 4 is also common to them.
Here's what you missed Icon_smile Or rather what the draftsman missed. Down at the bottom of the drawing where the tube filaments are shown connected in series the tubes are not labelled but the 7C6 would be the last one in the string closest to ground. Its standard procedure to have the detector tube as being the one 'closest' to ground in a series string so as to minimize hum.
http://www.nostalgiaair.org/PagesByModel...013592.pdf
A B- Question On My 46-250 - by Johnny - 06-18-2009, 04:49 PM
Re: A B- Question On My 46-250 - by exray - 06-18-2009, 05:04 PM
There are currently 11367 online users. [Complete List]
» 2 Member(s) | 11365 Guest(s)
