Sears silvertone question
This is true. Its just that most of the radios I've done has drawn about anywhere btwn. 300mA and 750mA. I only had it on about 15 minutes and the power transformer was barely warm . So I wanted to check with some of you guys before I
unintentionally did damage.
Sears silvertone question - by KCMike - 05-07-2016, 02:33 PM
RE: Sears silvertone question - by Phlogiston - 05-07-2016, 02:41 PM
RE: Sears silvertone question - by KCMike - 05-07-2016, 03:44 PM
RE: Sears silvertone question - by Phlogiston - 05-07-2016, 05:59 PM
RE: Sears silvertone question - by morzh - 05-07-2016, 03:47 PM
RE: Sears silvertone question - by KCMike - 05-07-2016, 03:59 PM
RE: Sears silvertone question - by KCMike - 05-07-2016, 06:23 PM
RE: Sears silvertone question - by KCMike - 05-09-2016, 12:44 PM
RE: Sears silvertone question - by Radioroslyn - 05-09-2016, 08:06 PM
RE: Sears silvertone question - by KCMike - 05-09-2016, 08:18 PM
RE: Sears silvertone question - by KCMike - 11-15-2016, 12:04 PM
RE: Sears silvertone question - by sam - 11-15-2016, 08:07 PM
RE: Sears silvertone question - by KCMike - 11-15-2016, 09:22 PM
RE: Sears silvertone question - by Phlogiston - 11-17-2016, 11:29 AM
RE: Sears silvertone question - by Radiola214 - 06-18-2019, 02:19 PM
RE: Sears silvertone question - by KCMike - 06-18-2019, 08:51 PM
RE: Sears silvertone question - by Radiola214 - 06-19-2019, 05:34 AM
RE: Sears silvertone question - by KCMike - 06-19-2019, 12:03 PM
RE: Sears silvertone question - by KCMike - 06-19-2019, 05:06 PM
RE: Sears silvertone question - by Radiola214 - 06-20-2019, 12:43 AM
