Lowboy 45 Speaker
Welcome to the Phorum!
Icon_wave
Ron has collected and posted (see the speakers.zip file) speaker information, unfortunately unless I missed it I only see the 5" speaker for the 45C model, not your 45L. Perhaps someone will have the info.
Lowboy 45 Speaker - by branthysell - 05-09-2016, 02:54 PM
RE: Lowboy 45 Speaker - by klondike98 - 05-09-2016, 06:53 PM
RE: Lowboy 45 Speaker - by Phlogiston - 05-09-2016, 07:26 PM
RE: Lowboy 45 Speaker - by klondike98 - 05-09-2016, 07:55 PM
RE: Lowboy 45 Speaker - by morzh - 05-09-2016, 08:13 PM
RE: Lowboy 45 Speaker - by Ron Ramirez - 05-09-2016, 08:53 PM
RE: Lowboy 45 Speaker - by Kenneth F. Besso Jr. - 05-09-2016, 09:15 PM
RE: Lowboy 45 Speaker - by morzh - 05-09-2016, 10:08 PM
RE: Lowboy 45 Speaker - by Kenneth F. Besso Jr. - 05-09-2016, 10:12 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
